Ana içeriğe geç
Polaroid S10 Battery Replacement
Neye ihtiyacın var
  1. Polaroid S10 Battery Replacement, Removing the backcover: adım 1, 3 resimden 1. Polaroid S10 Battery Replacement, Removing the backcover: adım 1, 3 resimden 2. Polaroid S10 Battery Replacement, Removing the backcover: adım 1, 3 resimden 3.
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: adım 2, 3 resimden 1. Polaroid S10 Battery Replacement, Battery: adım 2, 3 resimden 2. Polaroid S10 Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: adım 3, 2 resimden 1. Polaroid S10 Battery Replacement, Battery Connection: adım 3, 2 resimden 2.
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Sonuç
Follow these instructions to reassemble your device.
Bir başkası bu kılavuzu tamamladı.
James
367 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 1-4, May Spring 2015 Colorado Springs, Team 1-4, May Spring 2015 üyesi
UCCS-MAY-S15S1G4
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 5,196
