Ana içeriğe geç
Polaroid S10 volume button Replacement
Neye ihtiyacın var
  1. Polaroid S10 volume button Replacement, Removing the backcover: adım 1, 3 resimden 1. Polaroid S10 volume button Replacement, Removing the backcover: adım 1, 3 resimden 2. Polaroid S10 volume button Replacement, Removing the backcover: adım 1, 3 resimden 3.
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 volume button Replacement, Volume and Power Button Board: adım 2, 2 resimden 1. Polaroid S10 volume button Replacement, Volume and Power Button Board: adım 2, 2 resimden 2.
    • Use the spudger to remove the tape.
    • Remove the 2 J000 4 mm screws using a J000 screwdriver.
    • Carefully disconnect the connector port.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James
367 İtibar
3 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 1-4, May Spring 2015 Colorado Springs, Team 1-4, May Spring 2015 üyesi
UCCS-MAY-S15S1G4
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 346
