Ana içeriğe geç
Polaroid S7 Battery Replacement
Neye ihtiyacın var
    1. Polaroid S7 Battery Replacement, Remove the back: adım 1, 2 resimden 1. Polaroid S7 Battery Replacement, Remove the back: adım 1, 2 resimden 2.
      • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
      • Pry the two pieces apart.
      • Take care not to rip the ribbons that connect the screen to the back cover.
      FixBot'a Sor
      Yorum Ekle
    2. Polaroid S7 Battery Replacement: adım 2, 1 resimden 1.
      • Use a metal spudger to remove the orange sticker.
      FixBot'a Sor
      Yorum Ekle
    3. Polaroid S7 Battery Replacement: adım 3, 1 resimden 1.
      • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
      FixBot'a Sor
      Yorum Ekle
    4. Polaroid S7 Battery Replacement: adım 4, 2 resimden 1. Polaroid S7 Battery Replacement: adım 4, 2 resimden 2.
      • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
      • Pry the battery up from the right side.
      FixBot'a Sor
      Yorum Ekle
    5. Polaroid S7 Battery Replacement: adım 5, 1 resimden 1.
      • Remove the yellow plastic that covers the battery connector.
      FixBot'a Sor
      Yorum Ekle
    6. Polaroid S7 Battery Replacement: adım 6, 1 resimden 1.
      • Use a soldering iron to remove the wires connected to the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anthony Larratt
281 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Blackwell Winter 2015 USF Tampa, Team 1-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S1G2
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 3,543
