Ana içeriğe geç
Polaroid SNAP Battery Replacement
Neye ihtiyacın var
  1. Polaroid SNAP Battery Replacement, Polaroid SNAP Front and Back Face Plate Removal: adım 1, 1 resimden 1.
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Battery Replacement: adım 2, 2 resimden 1. Polaroid SNAP Battery Replacement: adım 2, 2 resimden 2.
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Battery Replacement: adım 3, 2 resimden 1. Polaroid SNAP Battery Replacement: adım 3, 2 resimden 2.
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Battery Replacement: adım 4, 3 resimden 1. Polaroid SNAP Battery Replacement: adım 4, 3 resimden 2. Polaroid SNAP Battery Replacement: adım 4, 3 resimden 3.
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Battery Replacement: adım 5, 1 resimden 1.
    • The cameras innards should now be accessible to you
  6. Polaroid SNAP Battery Replacement, Battery: adım 6, 1 resimden 1.
    • Two foam strips and adhesive glue binds the battery to the camera.
  7. Polaroid SNAP Battery Replacement: adım 7, 1 resimden 1.
    • Remove the battery by lifting up the battery from the left corner. If you can not remove the battery with your hands, consider using a Plastic Opening Tool
  8. Polaroid SNAP Battery Replacement: adım 8, 2 resimden 1. Polaroid SNAP Battery Replacement: adım 8, 2 resimden 2.
    • Using your fingers, remove the five pin connector from the device.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Ian Colantuoni
619 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-3, Cheng Spring 2016 USF Tampa, Team 7-3, Cheng Spring 2016 üyesi
USFT-CHENG-S16S7G3
4 Üyeler
18 adet Kılavuz yazıldı
23 Yorum
Thank you so much for showing me how to do this. FYI: For the digital LCD screen version of this camera, there is only one screw to take out on that first step.
Can you tell me where I can buy the replacement battery for this camera? Thanks.
Tommy Li - Yanıt
I would like to know where to buy it too.
Giorgina Nardi - Yanıt
Same question need to know where to purchase a new battery and is this a common issue for the snap touch
Anita Guzman - Yanıt
I also need a battery and it seems almost impossible to find one to buy. Please let me know if anybody has found a replacement battery that fits.
Jaco Botha - Yanıt
Has anyone managed to find where to buy a replacement battery?
ajm.smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 245
Son 30 gün: 939
Her zaman: 62,993
