Ana içeriğe geç
Polaroid Sun 600 LMS Lens Replacement
Neye ihtiyacın var
  1. Polaroid Sun 600 LMS Lens Replacement, Lens: adım 1, 2 resimden 1. Polaroid Sun 600 LMS Lens Replacement, Lens: adım 1, 2 resimden 2.
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Polaroid Sun 600 LMS Lens Replacement: adım 2, 2 resimden 1. Polaroid Sun 600 LMS Lens Replacement: adım 2, 2 resimden 2.
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
  3. Polaroid Sun 600 LMS Lens Replacement: adım 3, 2 resimden 1. Polaroid Sun 600 LMS Lens Replacement: adım 3, 2 resimden 2.
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
  4. Polaroid Sun 600 LMS Lens Replacement: adım 4, 2 resimden 1. Polaroid Sun 600 LMS Lens Replacement: adım 4, 2 resimden 2.
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
  5. Polaroid Sun 600 LMS Lens Replacement: adım 5, 2 resimden 1. Polaroid Sun 600 LMS Lens Replacement: adım 5, 2 resimden 2.
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
  6. Polaroid Sun 600 LMS Lens Replacement: adım 6, 2 resimden 1. Polaroid Sun 600 LMS Lens Replacement: adım 6, 2 resimden 2.
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ian Hosek
357 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-18, Maness Winter 2010 Cal Poly, Team 3-18, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G18
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 51
Her zaman: 10,661
