Ana içeriğe geç
Polaroid Z2300 Screen Replacement
Neye ihtiyacın var
  1. Polaroid Z2300 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Flip the camera to back side up and open the paper/screen door.
  2. Polaroid Z2300 Screen Replacement: adım 2, 3 resimden 1. Polaroid Z2300 Screen Replacement: adım 2, 3 resimden 2. Polaroid Z2300 Screen Replacement: adım 2, 3 resimden 3.
    • Locate and remove the two 3.5 mm long screws on the inside tray.
    • Screw head: JIS J00
    • Remove the inside tray.
    • The screws are very small! Be careful not to strip or lose them.
  3. Polaroid Z2300 Screen Replacement: adım 3, 2 resimden 1. Polaroid Z2300 Screen Replacement: adım 3, 2 resimden 2.
    • Gently pull the ribbon away from the logic board. This will allow the screen to separate from the rest of the camera.
  4. Polaroid Z2300 Screen Replacement: adım 4, 2 resimden 1. Polaroid Z2300 Screen Replacement: adım 4, 2 resimden 2.
    • Locate and remove four 3.5 mm long screws on the inside of the door.
  5. Polaroid Z2300 Screen Replacement: adım 5, 1 resimden 1.
    • Once the panel is removed, the malfunctioning screen will slide out and can be replaced.
Sonuç
Bradley Marcum
217 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Harley Fall 2018 IUPUI, Team S2-G1, Harley Fall 2018 üyesi
IUPUI-HARLEY-F18S2G1
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Where can I buy a replacement screen please?
mooi1uk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 415
