Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Polaroid i533 Outer Case Replacement, Outer Case: adım 1, 2 resimden 1. Polaroid i533 Outer Case Replacement, Outer Case: adım 1, 2 resimden 2.
    • Unscrew and remove the four screws from the left side of the camera (from the screen's view)
  2. Polaroid i533 Outer Case Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove the three screws from the bottom of the camera
  3. Polaroid i533 Outer Case Replacement: adım 3, 2 resimden 1. Polaroid i533 Outer Case Replacement: adım 3, 2 resimden 2.
    • Unscrew and remove the two screws from the right side of the camera.
  4. Polaroid i533 Outer Case Replacement: adım 4, 2 resimden 1. Polaroid i533 Outer Case Replacement: adım 4, 2 resimden 2.
    • Open the battery flap and remove the batteries.
    • Keep the battery flap open.
  5. Polaroid i533 Outer Case Replacement: adım 5, 1 resimden 1.
    • Use a spudger to gently separate the two halves of the camera's outer casing.
  6. Polaroid i533 Outer Case Replacement: adım 6, 1 resimden 1.
    • Gently pull the half of the case with the screen (the back half) from the rest of the camera.
    • Be sure not too pull to hard. The screen is still attached to the motherboard. If you pull too hard you will rip it.
  7. Polaroid i533 Outer Case Replacement: adım 7, 2 resimden 1. Polaroid i533 Outer Case Replacement: adım 7, 2 resimden 2.
    • The back half (the half with the screen on it) should now be separate from the rest of the camera, but still attached by the ribbon.
  8. Polaroid i533 Outer Case Replacement: adım 8, 2 resimden 1. Polaroid i533 Outer Case Replacement: adım 8, 2 resimden 2.
    • Use a spudger to lift the black flap that clamps the ribbon towards you.
    • When the black flap is open it will be straight up. (like in the second picture)
  9. Polaroid i533 Outer Case Replacement: adım 9, 1 resimden 1.
    • Now that the black flap is open, gently pull the ribbon out.
    • You should now have the back half of the camera completely separate from the rest of the camera.
  10. Polaroid i533 Outer Case Replacement: adım 10, 2 resimden 1. Polaroid i533 Outer Case Replacement: adım 10, 2 resimden 2.
    • This is what the back half of the camera should look like.
    • This is what the rest of the camera will look like.
  11. Polaroid i533 Outer Case Replacement: adım 11, 1 resimden 1.
    • Unscrew and remove two screws from the logic board.
  12. Polaroid i533 Outer Case Replacement: adım 12, 1 resimden 1.
    • Pull the front half off of the logic board.
  13. Polaroid i533 Outer Case Replacement: adım 13, 1 resimden 1.
    • This will be the front half of the outer case.
Sonuç
Terichael Office
9 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team 3-4, Johann Summer 2010 Cal Poly, Team 3-4, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S3G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,297
