Ana içeriğe geç
Polaroid i835 LCD Replacement
Neye ihtiyacın var
  1. Polaroid i835 LCD Replacement, LCD: adım 1, 3 resimden 1. Polaroid i835 LCD Replacement, LCD: adım 1, 3 resimden 2. Polaroid i835 LCD Replacement, LCD: adım 1, 3 resimden 3.
    • remove the batteries, the memory card as well as the carrying strip (if so equipped).
    • Remove the 2 screws on the right hand side.
    • Remove the 2 screws on the left hand side.
  2. Polaroid i835 LCD Replacement: adım 2, 3 resimden 1. Polaroid i835 LCD Replacement: adım 2, 3 resimden 2. Polaroid i835 LCD Replacement: adım 2, 3 resimden 3.
    • One more screw on the bottom, underneath the manufacturer's label.
    • Start spitting the case from the battery compartment. You can use a plastic opening tool, or your finger nails. It does bind a bit at the USB port side, but will separate pretty quick.
    • With the back removed, the large LCD becomes immediately visible. There are no fasteners, it just rests inside the tray.
  3. Polaroid i835 LCD Replacement: adım 3, 2 resimden 1. Polaroid i835 LCD Replacement: adım 3, 2 resimden 2.
    • Lift the LCD out of the tray and move it to the right of the tray. The cable is still attached to the logic board via a latch.
    • With the plastic opening tool, or your fingernails, gently flip the latch to the left side. This will free the LCD cable. Remove the LCD and install your new one.
Sonuç
oldturkey03
835.964 İtibar
123 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 1,383
