Ana içeriğe geç
Polk MagniFi Soundbar Bluetooth Cable Replacement
Neye ihtiyacın var
  1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: adım 1, 3 resimden 1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: adım 1, 3 resimden 2. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: adım 1, 3 resimden 3.
    • To reveal the control button, first, carefully remove the front cover of the Sound Bar.
    • Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
    • After the cover is fully removed, it will be able to see the interior speaker.
    • Carefully unscrew all 16 screws to release the panel.
    • There are total 16 screws that secures the panel onto the cover. Each screw is approximately 1.50 centimeter.
  2. Polk MagniFi Soundbar Bluetooth Cable Replacement: adım 2, 3 resimden 1. Polk MagniFi Soundbar Bluetooth Cable Replacement: adım 2, 3 resimden 2. Polk MagniFi Soundbar Bluetooth Cable Replacement: adım 2, 3 resimden 3.
    • To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
    • Push the opening tool along the edge of the cover to fully open it.
  3. Polk MagniFi Soundbar Bluetooth Cable Replacement: adım 3, 1 resimden 1.
    • Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
  4. Polk MagniFi Soundbar Bluetooth Cable Replacement: adım 4, 2 resimden 1. Polk MagniFi Soundbar Bluetooth Cable Replacement: adım 4, 2 resimden 2.
    • Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
    • This wire is easily broken. Handle with care.
Sonuç
[deleted]
671 İtibar
4 adet Kılavuz yazıldı
Bir Yorum
Can you pair it with Beats headphones.?
wayne rivers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 2,361
