Ana içeriğe geç
Polk MagniFi Soundbar Internal Power Adapter Replacement
Neye ihtiyacın var
  1. Polk MagniFi Soundbar Internal Power Adapter Replacement, Internal Power Adapter: adım 1, 1 resimden 1.
    • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips' head in size J1.
    • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed. This will be shown in the next step.
    • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
  2. Polk MagniFi Soundbar Internal Power Adapter Replacement: adım 2, 2 resimden 1. Polk MagniFi Soundbar Internal Power Adapter Replacement: adım 2, 2 resimden 2.
    • Underneath the back cover, there will be two flat panels, each with two 1cm screws.
    • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
  3. Polk MagniFi Soundbar Internal Power Adapter Replacement: adım 3, 2 resimden 1. Polk MagniFi Soundbar Internal Power Adapter Replacement: adım 3, 2 resimden 2.
    • To detach the cables grab the internal power adapter in one hand and with the other grab the base of the wires and firmly pull them straight out from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
[deleted]
671 İtibar
4 adet Kılavuz yazıldı
2 Yorum
where do you get the motherboard for this soundbar?
Tim - Yanıt
Where do we get replacement part?
Leon Haddrell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 2,371
