Ana içeriğe geç
Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement
Neye ihtiyacın var
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: adım 1, 3 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: adım 1, 3 resimden 2. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: adım 1, 3 resimden 3.
    • Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: adım 2, 2 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: adım 2, 2 resimden 2.
    • Grasp the plastic antenna foot and pull toward you.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: adım 3, 2 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: adım 3, 2 resimden 2.
    • Pull antenna from the top side of the phone base cover.
    • It helps if you gently wiggle the antenna back and forth to loosen the clips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tia
472 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 358
