Ana içeriğe geç
Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: adım 1, 3 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: adım 1, 3 resimden 2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: adım 1, 3 resimden 3.
    • Hold the mouthpiece of the handset and locate the lock-unlock text.
    • Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: adım 2, 3 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: adım 2, 3 resimden 2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: adım 2, 3 resimden 3.
    • To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: adım 3, 3 resimden 1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: adım 3, 3 resimden 2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: adım 3, 3 resimden 3.
    • Pull the battery from the battery compartment.
    • You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tia
472 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 909
