Ana içeriğe geç
Pop-Up Assembly Stopper Piece Replacement
Neye ihtiyacın var
  1. Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: adım 1, 2 resimden 1. Pop-Up Assembly Stopper Piece Replacement, Pop-Up Stopper Piece: adım 1, 2 resimden 2.
    • Place bucket directly under the sink below the pop-up assembly. Excess water may leak
    • The pivot rod that is inserted within a hole in the pop-up extension bar. Move the pop-up extension bar away from the pivot rod.
  2. Pop-Up Assembly Stopper Piece Replacement: adım 2, 1 resimden 1.
    • Disconnect the pivot rod from the center pop-up extension.
  3. Pop-Up Assembly Stopper Piece Replacement: adım 3, 2 resimden 1. Pop-Up Assembly Stopper Piece Replacement: adım 3, 2 resimden 2.
    • Lift up the center pop-up rod on the faucet until it is detached. The extension rod will pull up with it.
  4. Pop-Up Assembly Stopper Piece Replacement: adım 4, 3 resimden 1. Pop-Up Assembly Stopper Piece Replacement: adım 4, 3 resimden 2. Pop-Up Assembly Stopper Piece Replacement: adım 4, 3 resimden 3.
    • Below the sink is the pivot nut. Turn the pivot nut counterclockwise until it is completely loose and remove from the pivot rod.
  5. Pop-Up Assembly Stopper Piece Replacement: adım 5, 2 resimden 1. Pop-Up Assembly Stopper Piece Replacement: adım 5, 2 resimden 2.
    • Pull the pivot rod out to expose the ball. Remove the whole pivot rod fixture.
  6. Pop-Up Assembly Stopper Piece Replacement: adım 6, 2 resimden 1. Pop-Up Assembly Stopper Piece Replacement: adım 6, 2 resimden 2.
    • In the sink, the pop-up stopper will be loose.
    • Pull up on the pop-up stopper to separate it from the main pop-up assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,681
