Ana içeriğe geç
Portable Coby CD Player Drive Replacement
Neye ihtiyacın var
  1. Portable Coby CD Player Drive Replacement, Drive: adım 1, 1 resimden 1.
    • Turn the device off.
    • Unplug the device and remove the batteries.
  2. Portable Coby CD Player Drive Replacement: adım 2, 2 resimden 1. Portable Coby CD Player Drive Replacement: adım 2, 2 resimden 2.
    • Remove the three Phillips #0 screws from under the handle.
    • Remove the two Phillips #0 screws from inside the disc tray.
  3. Portable Coby CD Player Drive Replacement: adım 3, 3 resimden 1. Portable Coby CD Player Drive Replacement: adım 3, 3 resimden 2. Portable Coby CD Player Drive Replacement: adım 3, 3 resimden 3.
    • Pry open the top portion of the case using a spudger.
  4. Portable Coby CD Player Drive Replacement: adım 4, 2 resimden 1. Portable Coby CD Player Drive Replacement: adım 4, 2 resimden 2.
    • Lean the top portion of the case back.
    • Locate the drive.
  5. Portable Coby CD Player Drive Replacement: adım 5, 3 resimden 1. Portable Coby CD Player Drive Replacement: adım 5, 3 resimden 2. Portable Coby CD Player Drive Replacement: adım 5, 3 resimden 3.
    • Disconnect the four wires.
  6. Portable Coby CD Player Drive Replacement: adım 6, 1 resimden 1.
    • Remove the four Phillips #0 screws on the red and green washers.
  7. Portable Coby CD Player Drive Replacement: adım 7, 3 resimden 1. Portable Coby CD Player Drive Replacement: adım 7, 3 resimden 2. Portable Coby CD Player Drive Replacement: adım 7, 3 resimden 3.
    • Remove the drive.
    • Avoid hitting the metal bar above it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
dali imate laser za radio coby
Radovan Marinkovic - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,147
