Ana içeriğe geç
Portege Z830-S8302 Internal Cooling Fan Replacement
Neye ihtiyacın var
  1. Portege Z830-S8302 Internal Cooling Fan Replacement, Internal Cooling Fan: adım 1, 3 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement, Internal Cooling Fan: adım 1, 3 resimden 2. Portege Z830-S8302 Internal Cooling Fan Replacement, Internal Cooling Fan: adım 1, 3 resimden 3.
    • Flip the laptop over, with screen facing down to reveal bottom panel.
    • Remove thirteen 1.4mm Phillips #0 screws around the border of the frame.
  2. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 2, 3 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 2, 3 resimden 2. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Using the metal spudger, remove the rubber fitting in middle of back panel to reveal hidden screw.
    • Use a Torx T7 bit screwdriver to remove screw.
  3. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 3, 3 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 3, 3 resimden 2. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 3, 3 resimden 3.
    • Remove the SD card in top right hand corner of the device, next to the headphone ports.
    • Push in the SD card then pull out completely to remove from slot.
    • This will help in the removal of backplate.
  4. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 4, 2 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Lift the back plate starting at the opposing edge to the SD card. Lift from left to right and continue lifting this plate at this angle until its free from the laptop.
    • Once the backplate is completely off, this will reveal the inside components of the device.
  5. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 5, 3 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 5, 3 resimden 2. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Remove two 5mm Phillips #0 screws from the fan housing.
  6. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 6, 2 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 6, 2 resimden 2.
    • Use the nylon spudger to disconnect the wire (red/blue) plug from the motherboard.
    • Be gentle and do not apply too much pressure when removing the plug as the motherboard may be fragile.
  7. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 7, 2 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Lift up the wire and peel back the clear protective tape.
    • Split the black protective foam inside the tape in half to uncover the wires.
    • This should make the wires free of all connections.
  8. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 8, 2 resimden 1. Portege Z830-S8302 Internal Cooling Fan Replacement: adım 8, 2 resimden 2.
    • The fan is now free and able to be removed. Lift the fan out of place.
Sonuç
Tanner Krygier
913 İtibar
5 adet Kılavuz yazıldı
Ekip
Washington State, Team S2-G7, Hope Fall 2018 Washington State, Team S2-G7, Hope Fall 2018 üyesi
WSU-HOPE-F18S2G7
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 802
