Ana içeriğe geç
Portege Z830-S8302 Screen Replacement
Neye ihtiyacın var
  1. Portege Z830-S8302 Screen Replacement, Screen: adım 1, 3 resimden 1. Portege Z830-S8302 Screen Replacement, Screen: adım 1, 3 resimden 2. Portege Z830-S8302 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Use a plastic opening tool to gently pry plastic frame from screen. Detach all housing clips around the perimeter of the screen.
  2. Portege Z830-S8302 Screen Replacement: adım 2, 2 resimden 1. Portege Z830-S8302 Screen Replacement: adım 2, 2 resimden 2.
    • Remove two 3mm screws with a Phillips #000 screwdriver.
  3. Portege Z830-S8302 Screen Replacement: adım 3, 2 resimden 1. Portege Z830-S8302 Screen Replacement: adım 3, 2 resimden 2.
    • Wedge a blue plastic opening tool between the screen and the frame to free the screen.
    • Do not fully remove screen as it is still attached by connector cable on bottom
  4. Portege Z830-S8302 Screen Replacement: adım 4, 2 resimden 1. Portege Z830-S8302 Screen Replacement: adım 4, 2 resimden 2.
    • Disconnect the display cable with your fingers to fully remove the screen from the device.
Sonuç
Tanner Krygier
913 İtibar
5 adet Kılavuz yazıldı
Ekip
Washington State, Team S2-G7, Hope Fall 2018 Washington State, Team S2-G7, Hope Fall 2018 üyesi
WSU-HOPE-F18S2G7
3 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 454
