Ana içeriğe geç
Porter Cable 690LR Base Latch Replacement
Neye ihtiyacın var
  1. Porter Cable 690LR Base Latch Replacement, Base: adım 1, 2 resimden 1. Porter Cable 690LR Base Latch Replacement, Base: adım 1, 2 resimden 2.
    • Undo the black latch located on the base of the router by pulling upwards from underneath it.
  2. Porter Cable 690LR Base Latch Replacement: adım 2, 2 resimden 1. Porter Cable 690LR Base Latch Replacement: adım 2, 2 resimden 2.
    • Twist the base off the router.
    • You may need to jiggle the base of the router slightly.
  3. Porter Cable 690LR Base Latch Replacement, Base Latch: adım 3, 2 resimden 1. Porter Cable 690LR Base Latch Replacement, Base Latch: adım 3, 2 resimden 2.
    • Locate the 30 mm bolt and nut attaching the latch to the base.
    • Use a wrench to remove the nut attached to the bolt, freeing the latch from the base.
Sonuç
Jaymes Ullrich
343 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-7, Livingston Fall 2016 Cal Poly, Team 20-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S20G7
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 252
