Ana içeriğe geç
Porter-Cable 382 Dust Seal | Dust Break Replacement
Neye ihtiyacın var
  1. Porter-Cable 382 Dust Seal | Dust Break Replacement, Sander Pad: adım 1, 1 resimden 1.
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Dust Seal | Dust Break Replacement: adım 2, 1 resimden 1.
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
  3. Porter-Cable 382 Dust Seal | Dust Break Replacement, Dust Seal/ Break: adım 3, 1 resimden 1.
    • Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
  4. Porter-Cable 382 Dust Seal | Dust Break Replacement: adım 4, 2 resimden 1. Porter-Cable 382 Dust Seal | Dust Break Replacement: adım 4, 2 resimden 2.
    • Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
    • To reassemble, you will have to line up the protruding square with the key slot as shown otherwise your dust seal/ brake will not go back in.
Sonuç
jpfoxracing9
189 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 511
