Ana içeriğe geç
Porter-Cable 382 On/ Off Switch Replacement
Neye ihtiyacın var
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: adım 1, 2 resimden 1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: adım 1, 2 resimden 2.
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: adım 2, 2 resimden 1. Porter-Cable 382 On/ Off Switch Replacement: adım 2, 2 resimden 2.
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: adım 3, 1 resimden 1.
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Sonuç
Nick O'Sadcia
421 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 210
