Ana içeriğe geç
Porter-Cable 382 Sander Pad Replacement
Neye ihtiyacın var
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: adım 1, 1 resimden 1.
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: adım 2, 1 resimden 1.
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick O'Sadcia
421 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-7, Botvin Spring 2016 UMass Dartmouth, Team 8-7, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 1,744
