Ana içeriğe geç
Porter-Cable PC60TAG Motor Assembly Replacement
Neye ihtiyacın var
  1. Porter-Cable PC60TAG Motor Assembly Replacement, Motor Assembly: adım 1, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
  2. Porter-Cable PC60TAG Motor Assembly Replacement: adım 2, 1 resimden 1.
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Assembly Replacement: adım 3, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the1/2" Phillips screw holding on the motor brush arm. Repeat on the other side.
  4. Porter-Cable PC60TAG Motor Assembly Replacement: adım 4, 1 resimden 1.
    • Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
  5. Porter-Cable PC60TAG Motor Assembly Replacement: adım 5, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the 1 inch black retainer screw.
  6. Porter-Cable PC60TAG Motor Assembly Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #2screwdriver, remove the 4, 1/2" Phillips screws around the head gear.
  7. Porter-Cable PC60TAG Motor Assembly Replacement: adım 7, 1 resimden 1.
    • Carefully pull the head gear away from the device, and set aside.
  8. Porter-Cable PC60TAG Motor Assembly Replacement: adım 8, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the two, 1/2" screws holding the head to the body on the bottom side of the grinder.
  9. Porter-Cable PC60TAG Motor Assembly Replacement: adım 9, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the other two 1/2" screws holding the head to the body on the top side of the grinder.
  10. Porter-Cable PC60TAG Motor Assembly Replacement: adım 10, 1 resimden 1.
    • Holding the head of the device, carefully pull the motor assembly out of the body of the device.
  11. Porter-Cable PC60TAG Motor Assembly Replacement: adım 11, 1 resimden 1.
    • Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
  12. Porter-Cable PC60TAG Motor Assembly Replacement: adım 12, 1 resimden 1.
    • Pull the motor assembly away from the head.
Sonuç
Mackenzie Fairbanks
591 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 505
