Ana içeriğe geç
Porter-Cable PC60TAG Power Cord Replacement
Neye ihtiyacın var
  1. Porter-Cable PC60TAG Power Cord Replacement, Power Cord: adım 1, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Cord Replacement: adım 2, 1 resimden 1.
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Cord Replacement: adım 3, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
  4. Porter-Cable PC60TAG Power Cord Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  5. Porter-Cable PC60TAG Power Cord Replacement: adım 5, 1 resimden 1.
    • Careful remove each wire from the power cord from underneath the terminals.
Sonuç
Mackenzie Fairbanks
591 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 441
