Ana içeriğe geç
Porter-Cable PC60TAG Power Switch Replacement
Neye ihtiyacın var
  1. Porter-Cable PC60TAG Power Switch Replacement, Power Switch: adım 1, 1 resimden 1.
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Switch Replacement: adım 2, 1 resimden 1.
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Switch Replacement: adım 3, 1 resimden 1.
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  4. Porter-Cable PC60TAG Power Switch Replacement: adım 4, 1 resimden 1.
    • Careful remove each wire from the power cord from underneath the terminals.
  5. Porter-Cable PC60TAG Power Switch Replacement: adım 5, 1 resimden 1.
    • Using the spudger, carefully push the red power switch out of the device.
  6. Porter-Cable PC60TAG Power Switch Replacement: adım 6, 1 resimden 1.
    • From the other side of the device, use the spudger to carefully pry out power switch away from the device.
  7. Porter-Cable PC60TAG Power Switch Replacement: adım 7, 1 resimden 1.
    • Using your fingers, carefully remove each of the gold terminals from the power switch. You may need to gently wiggle the terminal back and forth in order to remove it.
Sonuç
Mackenzie Fairbanks
591 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 UMass Dartmouth, Team 2-2, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 15
Her zaman: 712
