Ana içeriğe geç
Porter-Cable PCE211 Brush Replacement
Neye ihtiyacın var
  1. Porter-Cable PCE211 Brush Replacement, Rear Housing: adım 1, 2 resimden 1. Porter-Cable PCE211 Brush Replacement, Rear Housing: adım 1, 2 resimden 2.
    • Remove the four 6 mm screws using a Phillips #2 screwdriver.
    • The screws are tight so you will need to use a bit of arm strength.
    FixBot'a Sor
    Yorum Ekle
  2. Porter-Cable PCE211 Brush Replacement: adım 2, 2 resimden 1. Porter-Cable PCE211 Brush Replacement: adım 2, 2 resimden 2.
    • Pull the rear housing off the back of the impact wrench.
    • Be careful when removing the rear case that loose parts don't get damaged.
    FixBot'a Sor
    Yorum Ekle
  3. Porter-Cable PCE211 Brush Replacement, Brush: adım 3, 2 resimden 1. Porter-Cable PCE211 Brush Replacement, Brush: adım 3, 2 resimden 2.
    • Remove the brushes connected to the red and black cords.
    • They are not secured so they made drop out naturally.
    FixBot'a Sor
    Yorum Ekle
  4. Porter-Cable PCE211 Brush Replacement: adım 4, 3 resimden 1. Porter-Cable PCE211 Brush Replacement: adım 4, 3 resimden 2. Porter-Cable PCE211 Brush Replacement: adım 4, 3 resimden 3.
    • Gently pull each brush off the corresponding cable to avoid damaging the cables.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Layla Berry
678 İtibar
7 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 674
