Ana içeriğe geç
Power Mac G4 Cube Airport Card Replacement
  1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: adım 1, 3 resimden 1. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: adım 1, 3 resimden 2. Power Mac G4 Cube Airport Card Replacement, Remove Cube Core: adım 1, 3 resimden 3.
    • Release the handle at the bottom of the Power Mac G4 Cube by pushing it down. Slowly pull out the cube by holding the end of the handle.
    • Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: adım 2, 2 resimden 1. Power Mac G4 Cube Airport Card Replacement, Accessing AirPort Card: adım 2, 2 resimden 2.
    • Pull outwards on the antenna cable.
    • The cable should pop out of the card without much force.
    • Pull on the clear tab outwards to remove the existing AirPort card
    • Slide in the new AirPort card.
    • Reconnect the antenna cable.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Ryan Chun
1.076 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G7
5 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 9,901
