Giriş
Installing the hard drive involves removing the outer case before actual installation.
Neye ihtiyacın var
Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
Push back the handle after you have taken the core out of the case.
Remove the three top screws of the hard drive use a T8 bit and remove the heat sink.
Carefully slide the hard drive to the open side (side without the IDE and power cables) to remove the drive.
Turn the drive over, remove the sled rail with a T10 driver for its two screws. Transfer the rail to the same side on the new drive.
Insert new hard drive.
21 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Strictly speaking, steps 2 through 4 aren’t necessary: you can just unscrew the heatsink from the hard drive, as in step 7, and carefully lift it out (I found that tilting it toward the optical drive and then pivoting it out worked).
