Ana içeriğe geç
Power Mac G4 Cube Optical Drive Replacement
Neye ihtiyacın var
  1. Power Mac G4 Cube Optical Drive Replacement, Outer Case: adım 1, 3 resimden 1. Power Mac G4 Cube Optical Drive Replacement, Outer Case: adım 1, 3 resimden 2. Power Mac G4 Cube Optical Drive Replacement, Outer Case: adım 1, 3 resimden 3.
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Optical Drive Replacement: adım 2, 2 resimden 1. Power Mac G4 Cube Optical Drive Replacement: adım 2, 2 resimden 2.
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Optical Drive Replacement: adım 3, 1 resimden 1.
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Optical Drive Replacement: adım 4, 1 resimden 1.
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Optical Drive Replacement, Optical Drive: adım 5, 1 resimden 1.
    • Remove a total of four screws on the sides of the optical drive.
  6. Power Mac G4 Cube Optical Drive Replacement: adım 6, 1 resimden 1.
    • Slowly lift up the optical drive and remove the IDE cable.
    • Remove the power cable.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Ryan Chun
1.076 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G7
5 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 54
Her zaman: 11,110
