Ana içeriğe geç
Power Mac G4 Cube RAM Replacement
Neye ihtiyacın var
  1. Power Mac G4 Cube RAM Replacement, Outer Case: adım 1, 3 resimden 1. Power Mac G4 Cube RAM Replacement, Outer Case: adım 1, 3 resimden 2. Power Mac G4 Cube RAM Replacement, Outer Case: adım 1, 3 resimden 3.
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
    FixBot'a Sor
    Yorum Ekle
  2. Power Mac G4 Cube RAM Replacement: adım 2, 2 resimden 1. Power Mac G4 Cube RAM Replacement: adım 2, 2 resimden 2.
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
    FixBot'a Sor
    Yorum Ekle
  3. Power Mac G4 Cube RAM Replacement: adım 3, 1 resimden 1.
    • Slowly lift the plate off the cube and disconnect the power cord.
    FixBot'a Sor
    Yorum Ekle
  4. Power Mac G4 Cube RAM Replacement: adım 4, 1 resimden 1.
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
    FixBot'a Sor
    Yorum Ekle
  5. Power Mac G4 Cube RAM Replacement, RAM: adım 5, 2 resimden 1. Power Mac G4 Cube RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Flip the two latches on the side of the RAM chip.
    • Remove the chip from the logic board and replace with new RAM.
    FixBot'a Sor
    Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Ryan Chun
1.076 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-7, Johann Summer 2010 Cal Poly, Team 2-7, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S2G7
5 Üyeler
28 adet Kılavuz yazıldı
1Rehber Yorum
Unless you have really fat fingers, you shouldn’t need to remove the metal plate and pillars. I’m able to replace the RAM without those steps.
Chris Sebes - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 123
Her zaman: 6,548
