Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Installing RAM involves removing the outer case before installation.
Neye ihtiyacın var
Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
Push back the handle after you have taken the core out of the case.
Flip the two latches on the side of the RAM chip.
Remove the chip from the logic board and replace with new RAM.
11 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Unless you have really fat fingers, you shouldn’t need to remove the metal plate and pillars. I’m able to replace the RAM without those steps.
