Ana içeriğe geç
Power Mac G4 M5183 Hard Drive Replacement
Neye ihtiyacın var
  1. Power Mac G4 M5183 Hard Drive Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Power Mac G4 M5183 Hard Drive Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 1. Power Mac G4 M5183 Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 2.
    • Remove the ribbon cable and power cable from the Hard Drive.
  3. Power Mac G4 M5183 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the screw which holds the Hard Drive tray in place.
  4. Power Mac G4 M5183 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Slide the Hard Drive tray out of the computer.
  5. Power Mac G4 M5183 Hard Drive Replacement: adım 5, 1 resimden 1.
    • To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
Bitiş Çizgisi
36 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
3.132 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
37 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 28,254
