Ana içeriğe geç
Power Mac G4 M5183 Internal Battery Replacement
  1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - Yanıt
  2. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: adım 2, 2 resimden 1. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: adım 2, 2 resimden 2.
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
Bitiş Çizgisi
21 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
3.114 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
25 adet Kılavuz yazıldı
4 Yorum
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - Yanıt
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - Yanıt
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - Yanıt
The PMU reset button is inside the casing, on the same circuit board as the backup battery holder. See the second photo, it's a small silver square with a circular black button inset into its top and PMU Reset in tiny white lettering beside it. The photo shows it near to the battery holder but on my model the button is further away on the far corner of the circuit board. Look around for it. Insert the new battery then press the reset ONE time only.
Robert Nicholson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 26
Son 30 gün: 102
Her zaman: 25,214
