Ana içeriğe geç
Power Mac G4 M5183 Logic Board Replacement
Neye ihtiyacın var
  1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: adım 2, 2 resimden 1. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: adım 2, 2 resimden 2.
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Logic Board Replacement: adım 3, 1 resimden 1.
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Logic Board Replacement, RAM: adım 4, 2 resimden 1. Power Mac G4 M5183 Logic Board Replacement, RAM: adım 4, 2 resimden 2.
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
  5. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: adım 5, 2 resimden 1. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: adım 5, 2 resimden 2.
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
  6. Power Mac G4 M5183 Logic Board Replacement, Logic Board: adım 6, 2 resimden 1. Power Mac G4 M5183 Logic Board Replacement, Logic Board: adım 6, 2 resimden 2.
    • Remove the six indicated cables attached to the logic board.
    • Use the spudger to remove the modem cable as indicated.
  7. Power Mac G4 M5183 Logic Board Replacement: adım 7, 2 resimden 1. Power Mac G4 M5183 Logic Board Replacement: adım 7, 2 resimden 2.
    • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
    • Carefully remove the CPU board from the Mother Board.
    • Remove the barrell nut screws from the Mother Board which held the CPU board.
    • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
    • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
    • Pull upwards and outwards to fully remove the logic board.
  8. Power Mac G4 M5183 Logic Board Replacement: adım 8, 1 resimden 1.
    • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
Bitiş Çizgisi
15 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
3.132 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
37 adet Kılavuz yazıldı
3Kılavuz Yorumları
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - Yanıt
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 18,711
