Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
How to remove the processor from the logic board.
  1. Pull on outer latch. Lower door until it is level with your work surface.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Use the spudger to pry the clips horizontally off of the heat sink. Fully remove the clips by lifting upwards.
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the heat sink by pulling upwards, off of the logic board.
    • Remove the heat sink by pulling upwards, off of the logic board.
  5. Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver. Remove processor by pulling vertically upwards.
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Bitiş Çizgisi
13 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
2.847 İtibar
11 adet Kılavuz yazıldı
Takım
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
20 adet Kılavuz yazıldı
2 Yorum
anyone still sell the replacement processor?
Joseph Cole - Yanıt
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 10,998
