Ana içeriğe geç
Power Mac G4 M5183 Processor Replacement
Neye ihtiyacın var
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: adım 1, 2 resimden 2.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - Yanıt
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: adım 2, 2 resimden 1. Power Mac G4 M5183 Processor Replacement, Heat Sink: adım 2, 2 resimden 2.
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Processor Replacement: adım 3, 1 resimden 1.
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Processor Replacement, Processor: adım 4, 2 resimden 1. Power Mac G4 M5183 Processor Replacement, Processor: adım 4, 2 resimden 2.
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
Bitiş Çizgisi
13 farklı kişi bu kılavuzu tamamladı.
Justin Petrilli
3.114 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G24
4 Üyeler
25 adet Kılavuz yazıldı
2 Yorum
anyone still sell the replacement processor?
Joseph Cole - Yanıt
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 12,069
