Ana içeriğe geç
Power Mac G4 Quicksilver Optical Drive Replacement
Neye ihtiyacın var
  1. Power Mac G4 Quicksilver Optical Drive Replacement, Opening the case: adım 1, 1 resimden 1.
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Optical Drive Replacement: adım 2, 2 resimden 1. Power Mac G4 Quicksilver Optical Drive Replacement: adım 2, 2 resimden 2.
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Optical Drive Replacement: adım 3, 1 resimden 1.
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Optical Drive Replacement, Optical Drive: adım 4, 1 resimden 1.
    • The optical drive is in the top left corner of the case.
  5. Power Mac G4 Quicksilver Optical Drive Replacement: adım 5, 2 resimden 1. Power Mac G4 Quicksilver Optical Drive Replacement: adım 5, 2 resimden 2.
    • There are four screws to be removed.
    • The first screw can be seen in the first picture.
    • The remaining three screws can be seen in the second picture.
  6. Power Mac G4 Quicksilver Optical Drive Replacement: adım 6, 1 resimden 1.
    • Remove the optical drive by pulling the drive away from the front of the computer and out.
  7. Power Mac G4 Quicksilver Optical Drive Replacement: adım 7, 1 resimden 1.
    • Detach the two cables attached to the back of the drive.
    • The flat ribbon cable can be detached by pulling the silver tab. The multicolored cable can be removed by grasping the plastic connector on either side and pulling with substantial force.
  8. Power Mac G4 Quicksilver Optical Drive Replacement, Optical Drive: adım 8, 1 resimden 1.
    • Remove the four screws holding the enclosure to the drive.
  9. Power Mac G4 Quicksilver Optical Drive Replacement: adım 9, 1 resimden 1.
    • Push on the back of the drive (side with the connectors) to slide the drive out of the enclosure.
    • Your optical drive is now ready to be replaced.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Ryan Bylard
1.325 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-41, Regan Winter 2010 Cal Poly, Team 14-41, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G41
4 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 11,654
