Ana içeriğe geç
Power Mac G5 CD-ROM Drive Replacement
    1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: adım 1, 1 resimden 1.
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      FixBot'a Sor
      Yorum Ekle
    2. Power Mac G5 CD-ROM Drive Replacement: adım 2, 1 resimden 1.
      • Remove all the cables, including the power cables before opening the unit.
      FixBot'a Sor
      Yorum Ekle
    3. Power Mac G5 CD-ROM Drive Replacement: adım 3, 2 resimden 1. Power Mac G5 CD-ROM Drive Replacement: adım 3, 2 resimden 2.
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      FixBot'a Sor
      Yorum Ekle
    4. Power Mac G5 CD-ROM Drive Replacement: adım 4, 3 resimden 1. Power Mac G5 CD-ROM Drive Replacement: adım 4, 3 resimden 2. Power Mac G5 CD-ROM Drive Replacement: adım 4, 3 resimden 3.
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      FixBot'a Sor
      Yorum Ekle
    1. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: adım 5, 1 resimden 1.
      • Locate the CD-ROM Drive on the top left corner of desktop.
      FixBot'a Sor
      Yorum Ekle
    2. Power Mac G5 CD-ROM Drive Replacement: adım 6, 3 resimden 1. Power Mac G5 CD-ROM Drive Replacement: adım 6, 3 resimden 2. Power Mac G5 CD-ROM Drive Replacement: adım 6, 3 resimden 3.
      • Pull and rotate latches to the left.
      FixBot'a Sor
      Yorum Ekle
    3. Power Mac G5 CD-ROM Drive Replacement: adım 7, 1 resimden 1.
      • Wiggle and pull out the CD Drive.
      FixBot'a Sor
      Yorum Ekle
    4. Power Mac G5 CD-ROM Drive Replacement: adım 8, 2 resimden 1. Power Mac G5 CD-ROM Drive Replacement: adım 8, 2 resimden 2.
      • Detach the first cable from the CD-ROM drive.
      • Detach the second cable from the CD-ROM drive.
      • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
      FixBot'a Sor
      Yorum Ekle
    5. Power Mac G5 CD-ROM Drive Replacement: adım 9, 1 resimden 1.
      • After the CD-ROM drive is removed, the area should look like this.
      FixBot'a Sor
      Yorum Ekle
Sonuç
44 farklı kişi bu kılavuzu tamamladı.
Jessica Chaidez
8.073 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G8
7 Üyeler
43 adet Kılavuz yazıldı
2Kılavuz Yorumları
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - Yanıt Paylaş
Misleading title. I know how to unplug the drive, thank you very much.
I've replaced the original drive with a better one and the %#*@ tray is stuck because it's too high.
engineer2137 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 96
Her zaman: 36,481
