Ana içeriğe geç
Power Mac G5 RAM Replacement
    1. Power Mac G5 RAM Replacement, Side Panel: adım 1, 1 resimden 1.
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      FixBot'a Sor
      Yorum Ekle
    2. Power Mac G5 RAM Replacement: adım 2, 1 resimden 1.
      • Remove all the cables, including the power cables before opening the unit.
      FixBot'a Sor
      Yorum Ekle
    3. Power Mac G5 RAM Replacement: adım 3, 2 resimden 1. Power Mac G5 RAM Replacement: adım 3, 2 resimden 2.
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      FixBot'a Sor
      Yorum Ekle
    4. Power Mac G5 RAM Replacement: adım 4, 3 resimden 1. Power Mac G5 RAM Replacement: adım 4, 3 resimden 2. Power Mac G5 RAM Replacement: adım 4, 3 resimden 3.
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      FixBot'a Sor
      Yorum Ekle
    1. Power Mac G5 RAM Replacement, Front Fan Assembly: adım 5, 1 resimden 1.
      • Locate the front fan assembly.
      FixBot'a Sor
      Yorum Ekle
    2. Power Mac G5 RAM Replacement: adım 6, 1 resimden 1.
      • Pull the fan assembly out; it should slide out easily.
      FixBot'a Sor
      Yorum Ekle
    1. Power Mac G5 RAM Replacement, RAM: adım 7, 1 resimden 1.
      • Locate the RAM on the Power Mac G5.
      FixBot'a Sor
      Yorum Ekle
    2. Power Mac G5 RAM Replacement: adım 8, 3 resimden 1. Power Mac G5 RAM Replacement: adım 8, 3 resimden 2. Power Mac G5 RAM Replacement: adım 8, 3 resimden 3.
      • Use your thumbs to push the RAM ejector pins to the sides.
      • The RAM module should pop up slightly.
      FixBot'a Sor
      Yorum Ekle
    3. Power Mac G5 RAM Replacement: adım 9, 1 resimden 1.
      • Remove the RAM module from the DIMM slot.
      • The RAM modules must be installed in pairs, with one module per bank (top and bottom).
      • When reinstalling the RAM, make sure to note the notch on the DIMM slot. This notch needs to line up with the corresponding gap on the RAM module.
      FixBot'a Sor
      Yorum Ekle
Sonuç
61 farklı kişi bu kılavuzu tamamladı.
Salvador Aguilar
2.550 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 üyesi
CPSU-FORTE-W10S5G8
7 Üyeler
43 adet Kılavuz yazıldı
2Kılavuz Yorumları
Major thing to note, you must install RAM in pairs. You can't just install one card on the top and not one on the bottom. Pairs start from the center and move outwards.
Red Rabbit 90 - Yanıt Paylaş
Very helpful
Kaiden Young - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 25
Son 30 gün: 108
Her zaman: 42,546
