1. Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
      • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Remove the single Phillips #1 screw circled in the picture. Set it aside for later. The graphics card is outlined in red in the second image, if you are confused on where this is.
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  4. Lift the graphics card straight out of it's PCI slot.
    • Lift the graphics card straight out of it's PCI slot.
      • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Cooke
15.689 İtibar
22 adet Kılavuz yazıldı
Takım
NIWOTech NIWOTech üyesi
Community
0 Üyeler
0 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 3
Son 30 Gün: 16
Her zaman: 94
