Ana içeriğe geç
Power Macintosh G3 Blue and White Graphics Card Replacement
Neye ihtiyacın var
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: adım 1, 1 resimden 1.
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: adım 2, 2 resimden 1. Power Macintosh G3 Blue and White Graphics Card Replacement: adım 2, 2 resimden 2.
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: adım 3, 1 resimden 1.
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
[deleted]
26.373 İtibar
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,538
