Ana içeriğe geç
Power Macintosh G3 Blue and White Modem Replacement
Neye ihtiyacın var
  1. Power Macintosh G3 Blue and White Modem Replacement, Before opening up your Power Mac...: adım 1, 1 resimden 1.
    • Remove the Phillips #1 screw circled in the picture. Set it aside for re-assembly.
  2. Power Macintosh G3 Blue and White Modem Replacement: adım 2, 1 resimden 1.
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  3. Power Macintosh G3 Blue and White Modem Replacement: adım 3, 1 resimden 1.
    • Remove the single Phillips #1 screw circled in the picture.
    • I apologize for the lack of picture quality. The only camera and lighting I had were my iPhone X´s camera and a table lamp. Lol!
  4. Power Macintosh G3 Blue and White Modem Replacement: adım 4, 1 resimden 1.
    • Disconnect the modem’s flex cable from the connector on the logic board.
    • Lift the modem assembly out of it´s place on the logic board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
[deleted]
26.409 İtibar
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 630
