Ana içeriğe geç
Power Macintosh G3 Blue and White RAM Replacement
Neye ihtiyacın var
  1. Power Macintosh G3 Blue and White RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals of the Power Mac.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White RAM Replacement: adım 2, 1 resimden 1.
    • Push the white tabs next to where your RAM is located away form the RAM chip itself.
    • The RAM chips should move up a tad and become somewhat loose.
    • Your RAM configuration may vary. This process is done the exact same way no matter what your RAM placement looks like.
  3. Power Macintosh G3 Blue and White RAM Replacement: adım 3, 2 resimden 1. Power Macintosh G3 Blue and White RAM Replacement: adım 3, 2 resimden 2.
    • Pull the RAM chips out of the RAM slots.
    • That's all folks! That wasn't too hard, was it?
    • Second image: RAM remains
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
[deleted]
26.409 İtibar
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 947
