Ana içeriğe geç
PowerA Enhanced 1516953-01 Joystick Cover Replacement
Neye ihtiyacın var
  1. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Rear Case: adım 1, 3 resimden 1. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Rear Case: adım 1, 3 resimden 2. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Rear Case: adım 1, 3 resimden 3.
    • Lay the controller face down.
    • Use a Phillips screwdriver to remove the eight 9.2 mm screws that secure the rear case.
    • Lift the rear case up and off of the chassis.
  2. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Motherboard: adım 2, 3 resimden 1. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Motherboard: adım 2, 3 resimden 2. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Motherboard: adım 2, 3 resimden 3.
    • Remove the two 3.3 mm Phillips screws that secure the motherboard to the front case.
    • Lift the motherboard up and out of the chassis.
  3. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Joystick Cover: adım 3, 3 resimden 1. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Joystick Cover: adım 3, 3 resimden 2. PowerA Enhanced 1516953-01 Joystick Cover Replacement, Joystick Cover: adım 3, 3 resimden 3.
    • Firmly pinch the left joystick cover and lift it straight up and off.
    • Firmly pinch the right joystick cover and lift it straight up and off.
Sonuç
Austin Fox
566 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 129
Her zaman: 531
