Ana içeriğe geç
PowerA Fusion Controller For Xbox One Analog Stick Replacement
Neye ihtiyacın var
  1. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: adım 1, 3 resimden 1. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: adım 1, 3 resimden 2. PowerA Fusion Controller For Xbox One Analog Stick Replacement, Analog Stick: adım 1, 3 resimden 3.
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Lift off the two bottom grip covers of the controller.
  2. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 2, 2 resimden 1. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 2, 2 resimden 2.
    • Remove the remaining (2) two 9.2mm screws holding the back cover with a JIS #1 screwdriver.
    • Carefully lift and remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 3, 3 resimden 1. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 3, 3 resimden 2. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 3, 3 resimden 3.
    • Carefully remove the (5) five 9.2mm screws holding the motherboard with a JIS #1 screwdriver.
    • Lift the motherboard and rest it face up to the right of the controller front plate.
  4. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 4, 2 resimden 1. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 4, 2 resimden 2.
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Remove the motherboard from the face plate of the controller.
  5. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 5, 2 resimden 1. PowerA Fusion Controller For Xbox One Analog Stick Replacement: adım 5, 2 resimden 2.
    • Use the tweezers to unclip the (4) four metal teeth of the analog stick.
    • Use the soldering iron and desoldering braid to desolder the analog stick sensor module from the back of the motherboard.
    • Place the new analog stick sensor module and solder it back.
    • Use the How To Solder and Desolder Connections guide on iFixit to help in desoldering and soldering the analog stick sensor module.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Marjan Mehedi
173 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G4
4 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - Yanıt
Have you found a replacement yet? I ran into the same problem a couple of months ago, the potenciometers that I ordered did not fit into the motherboard. I even tried some other ones from a generic USB controler to no avail. Manufacturers do not report the sizes of the potenciometers, so it’s a bet everytime. I yet have to find a potentiometer that fits…
Franco Valdés -
Any joy on purchasing these
Mike Jones -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 70
Her zaman: 15,021
