Ana içeriğe geç
PowerA Fusion Controller For Xbox One Buttons Replacement
Neye ihtiyacın var
  1. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: adım 1, 3 resimden 1. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: adım 1, 3 resimden 2. PowerA Fusion Controller For Xbox One Buttons Replacement, Buttons: adım 1, 3 resimden 3.
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 2, 2 resimden 1. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 2, 2 resimden 2.
    • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
    Would have been a better guide if you actually used a power a fusion controller.
    This is just a normal power a controller.
    Fusion has detachable cable and 4 detachable paddles on the back.
    Lol
    Qyuubix - Yanıt
  3. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 3, 3 resimden 1. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 3, 3 resimden 2. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 3, 3 resimden 3.
    • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
    • Lift the motherboard and let it hang.
  4. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 4, 2 resimden 1. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Put the motherboard aside.
  5. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 5, 2 resimden 1. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 5, 2 resimden 2.
    • Remove the buttons.
  6. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 6, 2 resimden 1. PowerA Fusion Controller For Xbox One Buttons Replacement: adım 6, 2 resimden 2.
    • Go back to the motherboard, and remove the buttons' gasket with a tweezler.
    What do you do after you remove the button gasket
    AcridAssassin - Yanıt
    Do the buttons come with the gasket? Also the buttons are for an Xbox One controller. Does that mean they are compatible?
    Alexi Macias - Yanıt
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Andrea
623 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G4
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
Okay so what do you do if by any chance one of the links that are sawdered to the mother board for the D Pad Connection cable breaks… Then what? How would I go about fixing that????
Heather Jesse - Yanıt
is there a guide to clean the bumpers out? my RB became less consistent and i'm hoping it's just because they're gunked up
urmum - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 80
Her zaman: 18,429
