Ana içeriğe geç
PowerA Spectra Infinity Enhanced Motherboard Replacement
Neye ihtiyacın var
  1. PowerA Spectra Infinity Enhanced Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. PowerA Spectra Infinity Enhanced Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Motherboard Replacement: adım 3, 2 resimden 1. PowerA Spectra Infinity Enhanced Motherboard Replacement: adım 3, 2 resimden 2.
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Motherboard Replacement: adım 5, 2 resimden 1. PowerA Spectra Infinity Enhanced Motherboard Replacement: adım 5, 2 resimden 2.
    • Use your hand to separate the motherboard from the face plate.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevyn Jorge
1.018 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-5, Botvin Spring 2024 UMass Dartmouth, Team 6-5, Botvin Spring 2024 üyesi
UMASSD-BOTVIN-S24S6G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 441
