Ana içeriğe geç
PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
Neye ihtiyacın var
  1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery.: adım 1, 1 resimden 1.
    • The battery is located inside the right side ear piece.
  2. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Heat Right Side.: adım 2, 1 resimden 1.
    • Heat the right side gently at 140 F for about 3 minutes.
    • Do not over heat or it will melt the housing.
  3. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: adım 3, 2 resimden 1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: adım 3, 2 resimden 2.
    • After heating, gently remove the cover/casing as shown in the picture.
    • Take your time and re-heat if cover/casing does not remove smoothly.
  4. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Desolder & Replace Battery: adım 4, 1 resimden 1.
    • Desolder battery using soldering iron and replace with replacement battery.
  5. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: adım 5, 2 resimden 1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: adım 5, 2 resimden 2.
    • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
    • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Faizan Naveed
3.294 İtibar
8 adet Kılavuz yazıldı
Ekip
Mobile Device Repair Factory Mobile Device Repair Factory üyesi
Business
1 Üye
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 49
Her zaman: 26,828
