Ana içeriğe geç
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
Neye ihtiyacın var
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: adım 1, 2 resimden 1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: adım 1, 2 resimden 2.
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: adım 2, 1 resimden 1.
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: adım 3, 3 resimden 1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: adım 3, 3 resimden 2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: adım 3, 3 resimden 3.
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: adım 4, 1 resimden 1.
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Faizan Naveed
3.294 İtibar
8 adet Kılavuz yazıldı
Ekip
Mobile Device Repair Factory Mobile Device Repair Factory üyesi
Business
1 Üye
16 adet Kılavuz yazıldı
5 Yorum
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - Yanıt
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Yanıt
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Yanıt
My bettry is too good work but tha wireis want to b change
Asoo Malik - Yanıt
Plzz tel me how I can change tha wire of my power beats
Asoo Malik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 100
Her zaman: 29,124
