Ana içeriğe geç
PowerBook 180 Modem Replacement
Neye ihtiyacın var
    1. PowerBook 180 Modem Replacement, Modem: adım 1, 2 resimden 1. PowerBook 180 Modem Replacement, Modem: adım 1, 2 resimden 2.
      • Remove the Ni-Cad battery from the PowerBook 180.
      • Slide the arrows toward the front of the computer until the battery can slide out.
      FixBot'a Sor
      Yorum Ekle
    2. PowerBook 180 Modem Replacement: adım 2, 2 resimden 1. PowerBook 180 Modem Replacement: adım 2, 2 resimden 2.
      • Removing the screws securing the bottom plate from the PowerBook 180.
      • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
      FixBot'a Sor
      Yorum Ekle
    3. PowerBook 180 Modem Replacement: adım 3, 2 resimden 1. PowerBook 180 Modem Replacement: adım 3, 2 resimden 2.
      • Your computer should look like the two pictures after the bottom plate is removed.
      FixBot'a Sor
      Yorum Ekle
    4. PowerBook 180 Modem Replacement: adım 4, 2 resimden 1. PowerBook 180 Modem Replacement: adım 4, 2 resimden 2.
      • Locate the modem board, which is next to the DC-in port.
      • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
      • To reassemble your PowerBook, follow these instructions in reverse.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jack Byrnes
1.244 İtibar
2 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
334 Üyeler
3.288 adet Kılavuz yazıldı
1Rehber Yorum
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 2,144
