Ana içeriğe geç
PowerBook 180 Ram Replacement
Neye ihtiyacın var
  1. PowerBook 180 Ram Replacement, Ram: adım 1, 2 resimden 1. PowerBook 180 Ram Replacement, Ram: adım 1, 2 resimden 2.
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. PowerBook 180 Ram Replacement: adım 2, 2 resimden 1. PowerBook 180 Ram Replacement: adım 2, 2 resimden 2.
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. PowerBook 180 Ram Replacement: adım 3, 2 resimden 1. PowerBook 180 Ram Replacement: adım 3, 2 resimden 2.
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  4. PowerBook 180 Ram Replacement: adım 4, 1 resimden 1.
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  5. PowerBook 180 Ram Replacement: adım 5, 2 resimden 1. PowerBook 180 Ram Replacement: adım 5, 2 resimden 2.
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jack Byrnes
1.244 İtibar
2 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 3,405
