Ana içeriğe geç
PowerBook 3400 M3553 RAM Replacement
Neye ihtiyacın var
  1. PowerBook 3400 M3553 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
    FixBot'a Sor
    Yorum Ekle
  2. PowerBook 3400 M3553 RAM Replacement: adım 2, 2 resimden 1. PowerBook 3400 M3553 RAM Replacement: adım 2, 2 resimden 2.
    • Hold the button on the front left side and slide the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. PowerBook 3400 M3553 RAM Replacement, Keyboard: adım 3, 1 resimden 1.
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
    FixBot'a Sor
    Yorum Ekle
  4. PowerBook 3400 M3553 RAM Replacement: adım 4, 3 resimden 1. PowerBook 3400 M3553 RAM Replacement: adım 4, 3 resimden 2. PowerBook 3400 M3553 RAM Replacement: adım 4, 3 resimden 3.
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
    FixBot'a Sor
    Yorum Ekle
  5. PowerBook 3400 M3553 RAM Replacement: adım 5, 2 resimden 1. PowerBook 3400 M3553 RAM Replacement: adım 5, 2 resimden 2.
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
    FixBot'a Sor
    Yorum Ekle
  6. PowerBook 3400 M3553 RAM Replacement, RAM: adım 6, 2 resimden 1. PowerBook 3400 M3553 RAM Replacement, RAM: adım 6, 2 resimden 2.
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To install the new RAM card, follow these steps in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Michael Mondragon
397 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-59, Amido Spring 2011 Cal Poly, Team 24-59, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G59
4 Üyeler
1Rehber Yorum
To reattach the keyboard I found it necessary to keep the kid open and push the keyboard all the way down; otherwise, the screws didn’t engage.
Scott - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 43
Her zaman: 3,190
